[GRASS-user] New modules in add-ons: v.in.geoplot, r.xtent + r.burn.frict
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Mon Sep 28 16:23:17 EDT 2009
The two are made for very different but equally specific purposes:
r.carve actually "carves" rivers into a DEM, subtracting their depths
from the DEM.
r.burn.frict does essentially the same job as v.to.rast would, except
it performs some anti-aliasing on line edges, so there is no case like
this:
   0100
   0010
   0001
where a cost surface algorithm that scans for 8 directions could
"slip" diagonally through the cells that represent a boundary line.
Instead, the line would be rasterized like this:
   0100
   0110
   0011
This is (only?) useful for rasterizing lines onto friction surfaces.
It's really just a primitive little script that I wrote because I needed
it for territorial modeling with r.xtent which involves cost surfaces.
Ben
Markus Neteler wrote:
> On Mon, Sep 28, 2009 at 4:26 PM, Benjamin Ducke
> <benjamin.ducke at oxfordarch.co.uk> wrote:
>> http://grass.osgeo.org/wiki/GRASS_AddOns#r.burn.frict
>> r.burn.frict converts vector geometries to raster cells, using a simple anti-aliasing method to close "gaps" between diagonal cells. Useful for "burning" vector geometries into a friction surface, making sure that simulated movement does not "slip" through converted cells that have only diagonal neighbours.
> Hi Benjamin,
> out of curiosity: what's the difference to r.carve?
> Markus
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
