[GRASS-user] starspan with grass support compilation failure
Jose Gomez-Dans
jgomezdans at gmail.com
Tue Sep 29 08:07:43 EDT 2009
2009/9/29 Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> On Tue, 2009-09-29 at 10:09 +0200, Xavier Delaunay wrote:
> > I had the same compilation error when compiling Starspan, although I am
> > not using GRASS. I googled the error message and I found your post.
If you are willing to use GDAL&Python, you can pretty much do whatever you
can do in starspan using the code & stuff on this page: <
http://sites.google.com/site/spatialpython/zonal-statistics>. It doesn't
necessarily output the results to a shapefile, but you can output stuff to a
CSV and then merge it with OGR's CSV driver. Performance is "pretty good" if
your images fit well in memory (I keep meaning to do a block version of it,
but since I'm spoilt for RAM, I never actually get round doing it! :D)
Cheers,
Jose
RSU ■ Dept. of Geography ■ University College ■ Gower St, London WC1E 6BT UK
EMM ■ Dept. of Geography ■ King's College ■ Strand, London WC2R 2LS UK
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090929/247d5cd9/attachment.html
