[GRASS-user] Removing short lines with one side "disconnected"???
incanus andresfr at unizar.es
Wed Sep 30 08:56:46 EDT 2009
wow!!!
thats it:
http://n2.nabble.com/file/n3742503/rdmangle.png
thanx!!!
:D
achim wrote:
> maybe
> v.clean input=wtrhhrt output=bewtbt tool=rmdangle thresh=999
> could help? Maybe serveral times with different threshs.
> Achim
> incanus schrieb:
>> Hi,
>> I'm trying to vectorize a map of streets, but after running r.thin and
>> r.to.vect i get this (the aspect is the same befor r.to.vect):
>> http://n2.nabble.com/file/n3741976/grassLineas.png
>> Now I want to remove the shorter lines keeping the principals. I've tried
>> with v.generalize with remove_small, but the central lines are a lot of
>> small lines and they are removed too.
>> Is any way to remove only the short areas with one side "disconnected" or
>> tu
>> join the segments of the principal lines?
>> thanx!
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/Removing-short-lines-with-one-side-disconnected-tp3741976p3742503.html
Sent from the Grass - Users mailing list archive at Nabble.com.
