[GRASS-user] National Elevation Data
William Kyngesburye
woklist at kyngchaos.com
Sun Apr 4 16:12:07 EDT 2010
When you select an area, and you are at the Request Summary page, click Modify Data Request. There you can select the Archive Format for each dataset.
I don't know if there is a way to change this *before* selecting areas.
On Apr 4, 2010, at 2:59 PM, Kurt Springs wrote:
> How do you set up the site to download tarball instead of .zip. I tried but it does not give me the option to download tarball.
> Kurt
> On Apr 3, 2010, at 3:15 PM, William Kyngesburye wrote:
>> I have found that the NED zips do this on OSX. So instead I change the download options to a tarball. Simpler than try to reconstruct the folder structure.
>> On Apr 3, 2010, at 2:01 PM, Kurt Springs wrote:
>>> I am using the Mac OS X Version. I downloaded the file NED_85826542\ned_85826542\w001001.adf. I tried changing the name to w001001.adf and got the same error.
>>> Kurt
>>> On Apr 3, 2010, at 3:13 AM, Markus Neteler wrote:
>>>> On Sat, Apr 3, 2010 at 2:47 AM, Kurt Springs <ferret_bard at mac.com> wrote:
>>>>> I tried that and got:
>>>>> r.in.gdal -e {input=/Users/kurtsprings/grassdata/NED_85826542/NED_85826542\ned_85826542\w001001.adf} output=dem
>>>>> ERROR 4: `/Users/kurtsprings/grassdata/NED_85826542/NED_85826542\ned_85826542\w001001.adf' not recognised as a supported file format.
>>>> I see switched \ and /. Looks like windows...?
>>>> Which winGRASS version do you use (too old?)?
>>>> Markus
>>>>> Also, I tried changing the name so that the file itself was just w001001.adf and got the same thing.
>>>>> Kurt
>>>>> On Apr 2, 2010, at 8:35 PM, Markus Neteler wrote:
>>>>>> On Sat, Apr 3, 2010 at 1:19 AM, Kurt Springs <ferret_bard at mac.com> wrote:
>>>>>>> Hi Folks,
>>>>>>> I downloaded a National Elevation Dataset layer from the USGS. I haven't any idea of how to import it as a raster layer. Its got several types of files: .dir, .dat, .nit, .aux, .adf, as well as some esri metadata files (.dbf, .prj, .shp, shx). Can anyone tell me which file is the one I want to try to import as a raster file?
>>>>>> Not sure, would this help?
>>>>>> http://grass.osgeo.org/wiki/HOWTO_import_USGS_elevation_data
>>>>>> Markus
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> Theory of the Universe
>> There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
>> -Hitchhiker's Guide to the Galaxy 2nd season intro
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
