[GRASS-user] v.net.iso - service area
Daniel Victoria daniel.victoria at gmail.com
Mon Apr 5 08:04:07 EDT 2010
If I understand you correctly, v.hull might help to create the service
area polygon from the points....
http://grass.itc.it/grass62/manuals/html62_user/v.hull.html
On Sun, Apr 4, 2010 at 8:12 PM, Richard Chirgwin
<rchirgwin at ozemail.com.au> wrote:
>> Message: 3
>> Date: Sat, 03 Apr 2010 23:11:26 +0200
>> From: "Johannes Sommer" <Johann.online at gmx.de>
>> Subject: [GRASS-user] v.net.iso - service area
>> To: grass-user at lists.osgeo.org
>> Message-ID: <20100403211126.313360 at gmx.net>
>> Content-Type: text/plain; charset="iso-8859-1"
>> Hi list,
>> recently I played around with the network functionality in ArcGIS. I
>> generated so called "Service Areas" in a network dataset which return the
>> regions that can be accessed in a network dataset based on several distances
>> (in my example 150, 400 meters).
>> I wanted to reproduce the results with GRASS GIS and after a short search
>> I found the module v.net.iso which seemed to fit my needs. It returns
>> exactly the same results as ArcGIS did on isolines on a network, but I can't
>> find any solution concerning the service areas.
>> Can anyone point me in the right direction to calculate zones (that is
>> "build polygons from the end points of each network segment") from these
>> generated isolines in a network?
>> Regards,
>> Johannes
> Johannes,
> I don't think there's anything to do this automatically in Grass-GIS. But I
> think you should be able to construct a script that would connect pairs of
> points.
> So if you can extract each end point of the network segment, you would end
> up with a vector containing only points - then create a temporary map of a
> point pair, run (say) v.distance output=connectors on each point pair, patch
> the resulting maps together ...
> It sounds a bit labourious, and probably someone else can think of something
> easier, but if you get all the individual steps right, a script is then easy
> to create.
> (Actually, Johannes, I think the idea is brilliant. I've done lots of
> network service area work, and it never occurred to me before!)
> Richard Chirgwin
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
