[GRASS-user] Problem with v.rast.stats
"António M. Rodrigues"
amrodrigues at fcsh.unl.pt
Tue Apr 6 04:45:31 EDT 2010
Please ignore this question...
On Apr 5, 2010, at 9:34 PM, António M. Rodrigues wrote:
> Hi,
> when using v.rast.stats to get stats for a raster over a polygon
> layer, I get the following error:
> DBMI-DBF driver error:
> Error while executing: 'ALTER TABLE caop09c2 ADD COLUMN a2_per0-10
> DOUBLE PRECISION
> Cannot continue (problem adding column).
> SQL parser error: syntax error, unexpected '-' processing '-'
> in statement:
> ALTER TABLE caop09c2 ADD COLUMN a2_per0-10 DOUBLE PRECISION
> Error in db_execute_immediate()
> Cannot continue (problem adding columns).
> This only happens when I choose the extended statistics option. If
> not, it works fine. Actually, GRASS
> adds all the new fields but does not calculate the quantiles.
> An extra question: is it possible to get more quantiles than those
> calculated using the default (1st,
> median and 3rd)?
> Thanks,
> António
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
