[GRASS-user] Problems in 3D visualisation
Yi Qiang yi_qiang at hotmail.com
Thu Apr 8 05:40:58 EDT 2010
I've got a problem when I was following a tutorial in Grass wiki
http://grass.osgeo.org/wiki/Help_with_3D#Region_settings
I import the 3D volume ASCII file (vox_data50.txt) into Grass. Then I try to
see profiles in NVIZ. I set several constants. But I can only see a empty 3D
box with nothing inside.
I successfully followed the example of Slovakia 3D precipitation. It works
well and I can see beautiful profiles.
I don't know what the problem is. I also manually create some 3D ASCII
files. None of them can be properly displayed in NVIZ. For example, I import
the following 3D ASCII file into grass but failed to visualize it.
north: 5
south: 0
east: 5
west: 0
top: 5
bottom: 0
rows: 5
cols: 5
levels: 5
2.5000 3.5000 4.5000 5.5000 6.5000
4.0000 5.0000 6.0000 7.0000 8.0000
6.5000 7.5000 8.5000 9.5000 10.5000
10.0000 11.0000 12.0000 13.0000 14.0000
14.5000 15.5000 16.5000 17.5000 18.5000
5.5000 6.5000 7.5000 8.5000 9.5000
7.0000 8.0000 9.0000 10.0000 11.0000
9.5000 10.5000 11.5000 12.5000 13.5000
13.0000 14.0000 15.0000 16.0000 17.0000
17.5000 18.5000 19.5000 20.5000 21.5000
10.5000 11.5000 12.5000 13.5000 14.5000
12.0000 13.0000 14.0000 15.0000 16.0000
18.0000 19.0000 20.0000 21.0000 22.0000
22.5000 23.5000 24.5000 25.5000 26.5000
19.0000 20.0000 21.0000 22.0000 23.0000
21.5000 22.5000 23.5000 24.5000 25.5000
25.0000 26.0000 27.0000 28.0000 29.0000
29.5000 30.5000 31.5000 32.5000 33.5000
26.5000 27.5000 28.5000 29.5000 30.5000
28.0000 29.0000 30.0000 31.0000 32.0000
30.5000 31.5000 32.5000 33.5000 34.5000
34.0000 35.0000 36.0000 37.0000 38.0000
38.5000 39.5000 40.5000 41.5000 42.5000
View this message in context: http://n2.nabble.com/Problems-in-3D-visualisation-tp4870092p4870092.html
Sent from the Grass - Users mailing list archive at Nabble.com.
