[GRASS-user] Error in GRASS6.4 while creating image group
Gilbert Ferrara
gilbertferrara1974 at gmail.com
Fri Apr 16 04:43:25 EDT 2010
I get exacly the same thing. In sub-group list nothing appears. I'm using
WinGRASS6.4RC5 and GRASS6.5 and GRASS6.4 from last week on Ubuntu...
Should it be reported as a bug?
On Wed, Apr 14, 2010 at 10:32 PM, Nikos Dumakis <nikosdu1980 at gmail.com>wrote:
> Does anyone reports the same? because that happened with Win32 and I'm
> using a snapshot from 10/4/2010 in Ubuntu9.10.
> It happens the same in i.cluster and in all the others menus that required
> groups...
> On Wed, Apr 14, 2010 at 9:11 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Wed, Apr 14, 2010 at 7:05 PM, Nikos Dumakis <nikosdu1980 at gmail.com>
>> wrote:
>> > Hi
>> > I'm using GRASS6.4.svn from latest week snapshot in Ubuntu and I was
>> testing
>> > a few functions while I got an error when creating a image group with
>> > NorthCarolina Dataset.
>> > I did:
>> > i.group group=gr04 subgroup=sub
>> > input=lsat7_2000_10 at landsat,lsat7_2000_20 at landsat,lsat7_2000_30 at landsat
>> ,lsat7_2000_40 at landsat,lsat7_2000_50 at landsat,lsat7_2000_70 at landsat
>> > And I got:
>> > Adding raster map <lsat7_2000_10 at landsat> to group
>> > Adding raster map <lsat7_2000_20 at landsat> to group
>> > Adding raster map <lsat7_2000_30 at landsat> to group
>> > Adding raster map <lsat7_2000_40 at landsat> to group
>> > Adding raster map <lsat7_2000_50 at landsat> to group
>> > Adding raster map <lsat7_2000_70 at landsat> to group
>> > Adding raster map <lsat7_2000_10 at landsat> to subgroup
>> > Adding raster map <lsat7_2000_20 at landsat> to subgroup
>> > Adding raster map <lsat7_2000_30 at landsat> to subgroup
>> > Adding raster map <lsat7_2000_40 at landsat> to subgroup
>> > Adding raster map <lsat7_2000_50 at landsat> to subgroup
>> > Adding raster map <lsat7_2000_70 at landsat> to subgroup
>> > Then when I open i.cluster GUI I selected gr04 group and, sub doesn't
>> appear
>> > in subgroup. It only appears "Not a selectable element". If I leave it
>> blank
>> > it doesn't run (sub group is a required option). But, if I write "sub"
>> it
>> > works...
>> > Is this suppose to happen?
>> I would say no. It reminds me of
>> http://trac.osgeo.org/grass/ticket/780
>> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100416/97b0e433/attachment.html
