[GRASS-user] Question with Python-SWIG example [SEC=UNCLASSIFIED]
Glynn Clements
glynn at gclements.plus.com
Tue Apr 20 09:59:38 EDT 2010
Andrew MacIntyre wrote:
> After some googling, it seems that the pointer address should be
> obtainable by using int() on the pointer object returned by the SWIG
> wrapper (i.e. int(p) in the above example), with the resulting value
> usable in ctypes' from_address() method. I might be wrong, but I think
> that e.g. ctypes.c_void_p(int(p)) might also work to create a ctypes
> void pointer instance.
That doesn't seem to work either:
> import grass.lib.grass as gis
> import grass.lib.raster as rast
> import ctypes
> gis.G_gisinit("")
> p = rast.Rast_allocate_c_buf()
> a = ctypes.cast(int(p), ctypes.POINTER(ctypes.c_int))
> infd = rast.Rast_open_old("elevation.dem", "")
> rast.Rast_get_c_row(infd, a, 10)
> a[0]
Segmentation fault (core dumped) 14:52:56
It's possible that the typemap is getting in the way here, but I have
no idea what should be done instead.
