[GRASS-user] GRASS7 - problem with startup
"António M. Rodrigues"
amrodrigues at fcsh.unl.pt
Wed Apr 21 06:17:12 EDT 2010
Sorry for forgetting to change the subject of my previous message...
On Apr 21, 2010, at 11:07 AM, António M. Rodrigues wrote:
> Hi.
> I have recently compiled GRASS7 (MAC OSX), using:
> ./configure --with-freetype --with-freetype-includes="/Library/
> Frameworks/FreeType.framework/unix/include/freetype2 /Library/
> Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/
> Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/
> Frameworks/GDAL.framework/Programs/gdal-config --with-geos=/Library/
> Frameworks/GEOS.framework/Programs/geos-config --with-proj --with-
> proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-
> proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-
> share=/Library/Frameworks/PROJ.framework/Resources/proj --with-jpeg-
> includes=/Library/Frameworks/UnixImageIO.framework/unix/include --
> with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --
> with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/
> include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/
> unix/lib --with-tiff-includes=/Library/Frameworks/
> UnixImageIO.framework/unix/include --with-tiff-libs=/Library/
> Frameworks/UnixImageIO.framework/unix/lib --without-postgres --
> without-mysql --with-odbc --with-sqlite --with-sqlite-libs=/Library/
> Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/
> Library/Frameworks/SQLite3.framework/unix/include --with-fftw-
> includes=/Library/Frameworks/FFTW3.framework/unix/include --with-
> fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-cxx --
> with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers /
> Library/Frameworks/Tk.framework/Headers /Library/Frameworks/
> Tk.framework/PrivateHeaders" --with-tcltk-libs=/usr/local/lib --with-
> x --without-motif --without-glw --with-opengl=aqua --without-
> readline --without-cairo --prefix=/Applications --enable-macosx-app
> make
> make install
> All this went fine (after some initial problems). Now, when I
> startup the application I get the following error message:
> '/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
> norte:~ antonio$ '/Applications/GRASS-7.0.app/Contents/MacOS/
> grass.sh'; exit
> Rebuilding Addon HTML manual pages index...
> Rebuilding Addon menu...
> Python 2.5.1 found.
> /Applications/GRASS-7.0.app/Contents/MacOS/grass.sh: line 220: /
> Applications/GRASS-7.0.app/Contents/MacOS/etc/Init.sh: No such file
> or directory
> exec: /Applications/GRASS-7.0.app/Contents/MacOS/etc/Init.sh: cannot
> execute: No such file or directory
> logout
> [Process completed]
> I tried to google the problem, but didn't really find anything. So,
> I just tried to copy the init.sh from GRASS6.4 into the GRASS7 app
> to see what happened. After the first welcome menu, I get:
> Starting GRASS ...
> Error in startup script: couldn't read file "/Applications/
> GRASS-7.0.app/Contents/MacOS/etc/gis_set.tcl": no such file or
> directory
> Error in GUI startup. If necessary, please
> report this error to the GRASS developers.
> Switching to text mode now.
> Hit RETURN to continue...
> /Applications/GRASS-7.0.app/Contents/MacOS/etc/Init.sh: line 643: /
> Applications/GRASS-7.0.app/Contents/MacOS/etc/set_data: No such file
> or directory
> logout
> I suspect the problem may have to do with the new GUI and the python
> version which comes pre-installed with MAC OS. I had problems in the
> past trying to run some QGIS plugins (ex: ManageR), a problems which
> I have not yet been able to solve (any help on this is moslty
> welcomed).
> Other than trying to solve the problem with python, I guess the
> simplest thing would be to start GRASS with the older GUI (which I'm
> perfectly happy with, running GRASS6.4 with no problems at all). But
> how do I do this?
> Thanks you,
> António
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
