[GRASS-user] Question with Python-SWIG example [SEC=UNCLASSIFIED]
Andrew MacIntyre Andrew.MacIntyre at acma.gov.au
Wed Apr 21 21:14:49 EDT 2010
> From: Glynn Clements
> Andrew MacIntyre wrote:
> > > > After some googling, it seems that the pointer address should be
> > > > obtainable by using int() on the pointer object returned by the
SWIG
> > > > wrapper (i.e. int(p) in the above example), with the resulting
value
> > > > usable in ctypes' from_address() method.  I might be wrong, but
I
> > > > think that e.g. ctypes.c_void_p(int(p)) might also work to
create a
> > > > ctypes void pointer instance.
> > > That doesn't seem to work either:
> > > 	> import grass.lib.grass as gis
> > > 	> import grass.lib.raster as rast
> > > 	> import ctypes
> > > 	> gis.G_gisinit("")
> > > 	> p = rast.Rast_allocate_c_buf()
> > > 	> a = ctypes.cast(int(p), ctypes.POINTER(ctypes.c_int))
> > > 	> infd = rast.Rast_open_old("elevation.dem", "")
> > > 	> rast.Rast_get_c_row(infd, a, 10)
> > I think the above line should read:
> >  	rast. Rast_get_c_row(infd, p, 10)
> That was what I tried first, but it results in Rast_get_c_row()
> segfaulting.
Then it seems to me that there's some problem with the SWIG wrapper for
Rast_get_c_row(), if it won't accept a valid SWIG pointer object
returned from another wrapped function.
> There is a typemap for pointers, which converts a CObject, string,
> buffer or sequence. I have no idea how to test for or convert a
> SWIG-wrapped pointer.
In the SWIG wrapper?  I see a note about SWIG_ConvertPtr() in
http://www.swig.org/Doc1.3/Python.html#Python_nn64 ?
> The fact that passing "a" doesn't segfault appears to indicate that it
> was successfully converted to a pointer. The fact that accessing a[0]
> afterwards leads me to suspect that it may be getting converted to a
> pointer to the "container" rather than to the array proper.
Well, "a" is a ctypes object, so  I wouldn't have expected a useful
coercion.
Sadly, I doubt I can contribute much more to this matter :(
Andrew.
-------------------------> "These thoughts are mine alone!" <---------
Andrew MacIntyre           Operations Branch
tel:   +61 2 6219 5356     Communications Infrastructure Division
fax:   +61 2 6253 3277     Australian Communications & Media Authority
email: andrew.macintyre at acma.gov.au            http://www.acma.gov.au/
If you have received this email in error, please notify the sender immediately and erase all copies of the email and any attachments to it. The information contained in this email and any attachments may be private, confidential and legally privileged or the subject of copyright. If you are not the addressee it may be illegal to review, disclose, use, forward, or distribute this email and/or its contents.
Unless otherwise specified, the information in the email and any attachments is intended as a guide only and should not be relied upon as legal or technical advice or regarded as a substitute for legal or technical advice in individual cases. Opinions contained in this email or any of its attachments do not necessarily reflect the opinions of ACMA.
