[GRASS-user] Calculate statistics for raster values in polygons
Luis Lisboa
luislisboa1975 at gmail.com
Thu Apr 22 04:21:02 EDT 2010
Hi all
I'm reading the v.rast.stats Help and I'm a bit confused. It says "Calculates
basic univariate statistics from a raster map only for the parts covered by
the specified vector map". But for instance if all my region is covered by
different polygons and, if I want to calculate for each polygon my average
value from raster, is this function helpful? (e.g. I have vector with zip
codes for my region and I want to calculate average elevation of each zip
code).
On Wed, Apr 21, 2010 at 6:21 PM, Jarek Jasiewicz <jarekj at amu.edu.pl> wrote:
> Luis Lisboa pisze:
>> Greetings
>> I have a vectorial data that divides my region in sub-areas. I want to
>> calculate the average value of a raster but instead for all pixel values, I
>> want to calculate the average of pixel values that are inside each polygonIs
>> this possible in GRASS? If yes, how?
>> Thank you
>> Luis
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> v.rast.stats
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100422/06e8eeec/attachment.html
