[GRASS-user] Re: algorithm used in i.cluster
Georg Kaspar georg at muenster.de
Thu Apr 22 11:21:38 EDT 2010
Georg Kaspar schrieb:
> the steps described in
> http://download.osgeo.org/grass/grass6_progman/c__exec_8c_source.html
> seem to fit the migrating means algorithm described in richards and jia
> (2006) and based on the isodata algorithm in ball and hall (1965):
which is in principle the same as k-means.
I wrote a mail to Michael Shapiro, who wrote the code back in the 90's
and received this answer:
> Georg,
> It has been a very long time since I wrote that code so my memory may be suspect, but I think that is correct.
> ----- Original Message -----
> From: "Georg Kaspar" <georg.kaspar at uni-muenster.de>
> To: mshapiro at ncsa.illinois.edu
> Sent: Thursday, April 22, 2010 10:09:57 AM
> Subject: algorithm used in GRASS module i.cluster
> Dear Mr Shapiro,
> for my diploma thesis I need to know the algorithm implemented in the
> GRASS GIS module "i.cluster". I had a quick look at the source code and
> think that it uses an iterative process similar to k-means clustering.
> Can you confirm this assumption?
> Thank you very much in advance!
> best regards,
> Georg Kaspar
