[GRASS-user] Error with sub-group while using i.gensigset
Luisa Peña
luisapena1979 at gmail.com
Fri Apr 23 04:56:49 EDT 2010
So as far as I can see, users Must KNOW which name they gave to their
subgroups right? Since this option it's not working, my suggestion is to
eliminate this combo-box and subsitute by a text box...
2010/4/17 Markus Neteler <neteler at osgeo.org>
asas
> On Thu, Apr 15, 2010 at 12:37 AM, Luisa Peña <luisapena1979 at gmail.com>
> wrote:
> > I have re-downloaded NC_spm_08 from GRASS website and the already
> available
> > group, lsat7_2000 at landsat doesn't display sub-group in i.cluster or
> other
> > functions..
> > Nevertheless, I tried what Markus said:
> > i.group group=t02 subgroup=sub input=lsat5_1987_10,lsat5_1987_20 (altough
> > this is not performed by GUI but by me on the command output)
> > Adding raster map <lsat5_1987_10 at landsat> to group
> > Adding raster map <lsat5_1987_20 at landsat> to group
> > Adding raster map <lsat5_1987_10 at landsat> to subgroup
> > Adding raster map <lsat5_1987_20 at landsat> to subgroup
> > i.group complete.
> > And then at i.cluster when I select t02, in subgroup there is no
> sub-group
> > only "NOT SELECTABLE ELEMENT".
> > What am I missing/or might be wrong?
> This is a known bug in the wxGUI which is unfortunately still open..
> http://trac.osgeo.org/grass/ticket/780
> On command line and in the TclTK GUI it should work.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100423/c0b324db/attachment.html
