[GRASS-user] Problem after import using r.in.ascii
Glynn Clements
glynn at gclements.plus.com
Wed Apr 28 16:42:47 EDT 2010
Hanlie Pretorius wrote:
> I have an existing CSV file that has the headers lat, long and precip.
> The precipitation is a floating point number to two decimal places.
> The coordinates in the CSV file define the centre of a quarter degree
> square. The first set of coordinates in the file is -19.625,15.875.
> Becuase the TRMM data defines the centre of the square, I subtracted
> 0.125 from the first set of coordinates to get the north-west corner
> of the raster. And I added 0.125 to the last coordinate in the CSV
> file, which is -34.875,34.125, to get the south-east corner of the
> raster.
This seems wrong; positive-X is east, positive-Y is north, so you
should be adding to north and east, subtracting from south and west.
> In the CSV file, the latitude stays constant for 74 rows while the
> longitude increments in quarter degree steps. The whole file contains
> 4588 rows, so a grid of the data should have 74 rows and 62 columns,
> right?
> So I reformatted the data to 74 rows and 62 columns and added the header:
> north: -19.5
> south: -35.0
> east: 15.75
> west: 34.25
Positive-X is east, so either east and west are the wrong way around,
or they should both be negative, or this represents a span of 341.5
degrees.
> rows: 74
> cols: 62
> null: -319.99
> The output of g.region -p is:
> projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 18S
> south: 36S
> west: 15E
> east: 35E
Here, east and west have been swapped relative to what you say above.
> nsres: 0:15
> ewres: 0:15
> rows: 72
> cols: 80
> cells: 5760
> I then imported the reformatted file using the command:
> r.in.ascii -f input="3B42RT.2010032409.6.bin.sa.grass"\
> output="2010032409.6.precip" \
> title="Precipitation 2010032409.6"\
> mult=1.0 or read from header nv="* or read from header"
> When imported, I get two thin strips of data on the sides of the
> image. The raster shouldn't contain any nulls (the text file doesn't
> contain the value -319.99), so something is wrong.
> r.info gives a very strange resolutions:
> | Type of Map: raster Number of Categories: 255
> | Data Type: FCELL
> | Rows: 74
> | Columns: 62
> | Total Cells: 4588
> | Projection: Latitude-Longitude
> | N: 19:30S S: 35S Res: 0:12:34.054054
> | E: 15:45E W: 34:15E Res: 5:30:29.032258
The west edge is east of the east edge, resulting in a span of 341.5
degrees. 341.5 / 62 = 5.508064516129032 = 5:30:29.032258.
> | Range of data: min = 0.000000 max = 7.470000
> Can someone perhaps help me to see what's happening here?
East and west are swapped.
