[GRASS-user] Re: osm import
Casey Vandenberg casey.vandenberg at sjgeophysics.com
Thu Apr 29 12:34:13 EDT 2010
There are scripts that exist for converting osm to gml. Then they can be
imported directly using ogr.
I did not have much luck with using XSLT with the the xml styles
location on the Open Street Map wiki
(http://wiki.openstreetmap.org/wiki/Converting_OSM_to_GML), but the
python script (http://www.chzsoft.de/geo/osm2gml.py.txt) worked well for me.
Casey
grass-user-request at lists.osgeo.org wrote:
> Send grass-user mailing list submissions to
> 	grass-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
>    1. Re: osm import (Moritz Lennert)
> Message: 1
> Date: Thu, 29 Apr 2010 16:36:20 +0200
> From: Moritz Lennert <mlennert at club.worldonline.be>
> Subject: [GRASS-user] Re: osm import
> To: Hamish <hamish_b at yahoo.com>
> Cc: grass-user at lists.osgeo.org, Mathieu De Maeyer <mdemaeye at ulb.ac.be>
> Message-ID: <4BD99964.9090505 at club.worldonline.be>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> On 29/04/10 15:37, Hamish wrote:
>> Moritz wrote:
>>> In a recent post [1], you said that to import OSM maps, one
>>> can use v.in.ogr, but I don't see a driver for OSM maps in
>>> ogr. Could you explain ?
>> umm, probably just a dream, it was a former Summer of Code wish
>> for GDAL which apparently never happened.
> Yes, I saw that, too. Nice dream, though ;-)
>> a web search finds these which may help:
>>    http://www.google.co.nz/search?q=osm2shp  (.shp will be lossy!)
> apparently .NET-based, don't know if it works with Mono.
> But obviously the easiest is just to use the CloudMade shapefiles:
> http://downloads.cloudmade.com/
>>    http://svn.openstreetmap.org/applications/utils/import/ogr2osm/ogr2osm.py
> That works the other way around, i.e. ogr -> osm, or ?
>> and a crappy old osm2grass script I wrote circa GRASS 6.1:
>>    http://sites.google.com/site/hamishbowman/gpsdrivefiles#osm
>> but probably your best bet is to try the v.in.gpsbabel module
>> with a recent version of GpsBabel. ([to be] renamed/rewritten as
>> v.in.gps in GRASS 7)
> Sounds like an interesting solution. Limited to lines and points,
> though, or ? For the record, that's gpsbabel 1.3.5+
>> and probably the best near-term strategy is to help verify that
>> GpsBabel's import filter does not lose any data in the OSM tag
>> ->  GPX attribute conversion.
> I'll ask my colleagues who might use this to check.
>> then either v.in.ogr + OGR's GPX driver or v.in.gpsbabel's GPX.
> Why not directly v.in.gpsbabel on the osm file ?
>> finally "osm2pgsql"
> for the record: http://wiki.openstreetmap.org/wiki/Osm2pgsql
>> and then connect GRASS to the PostGIS database
>> might be the most robust approach. I don't know much about
>> PostGIS ->  GRASS but it is something I'd like to read about on
>> a GRASS wiki page :)
> Well, it should be a simple v.in.ogr. There is an example on the
> v.in.ogr man page.
> Thanks for the exhaustive response !
> Moritz
> End of grass-user Digest, Vol 48, Issue 70
Casey Vandenberg Geomatics Specialist
SJ Geophysics Ltd. / S.J.V. Consultants Ltd.
11966 95A Avenue Delta, BC, Canada, V4C 3W2
Office: 604.582.1100
Mobile: 778.928.1103
www.sjgeophysics.com
