[GRASS-user] Angle between segments of a polyline
Jarek Jasiewicz jarekj at amu.edu.pl
Tue Aug 3 08:34:39 EDT 2010
Rainer M Krug pisze:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi
> a friend of mine wants (needs?) to determine the angle between segments
> in an ESRI polyline (line vector feature). As there does not seem to be
> an easy way in ArcGIS 9.2, I thought about askeng here:
> Is there way of calculating these angles between the different line
> segments in grass?
If problem concerns stream network, try to use r.stream.angle exension
J.
