[GRASS-user] Script from GRASS 6.4 to 7 - g.ask
Rebecca Bennett rabennett at ymail.com
Tue Aug 3 08:57:09 EDT 2010
Hello all,
I am trying to run a script in GRASS 7 (which was kindly written for me by Micha
Silva for GRASS 6.4) which requires the g.ask module that I believe has been
removed (http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures). With what should
I replace this this command?
Thanks in advance,
Rebecca
To: grass-user at lists.osgeo.org
Sent: Tue, 3 August, 2010 12:37:33
Subject: [GRASS-user] Re: Installing r.area
Alright... I tried the following:
Lee at pc19384:~> svn checkout
https://svn.osgeo.org/grass/grass-addons/raster/r.area/
A    r.area/main.c
A    r.area/description.html
A    r.area/Makefile
Ausgecheckt, Revision 42981.
Lee at pc19384:~> cd r.area/
Lee at pc19384:~/r.area> make MODULE_TOPDIR=/opt/grass/
test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
gcc -I/usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/include
-O2       -DPACKAGE=\""grassmods"\"
-I/usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c:19:23: schwerwiegender Fehler: grass/gis.h: Datei oder Verzeichnis
nicht gefunden
Kompilierung beendet.
make: *** [OBJ.i686-pc-linux-gnu/main.o] Fehler 1
Same error message, it doesn't find what it's looking for.
I looked at the error report and was a bit confused. Does this mean that
there's no way around this other than compiling GRASS from source? Or is it
perhaps possible to download the GRASS source and keep my distributed GRASS
version and just use the source to compile r.area?
Thanks,
Daniel
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Installing-r-area-tp5340139p5367915.html
Sent from the Grass - Users mailing list archive at Nabble.com.
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100803/d93834d4/attachment.html
