[GRASS-user] Longest flow path
stephen sefick
ssefick at gmail.com
Tue Aug 3 12:01:48 EDT 2010
I realized this later... I didn't mean to come off as a jerk if I
did. I am in everyone's debt who has written or otherwise contributed
to all free software projects. Thank you to all of those named and
un-named.
Stephen
On Tue, Aug 3, 2010 at 8:32 AM, stephen sefick <ssefick at gmail.com> wrote:
> To add on to Rich's comments. I will gladly suggest things that would
> be helpful to applied stream ecologists that could be used by a great
> many folks. I will help in any way. I am finding that I need to
> write a fair amount of shell script to extract the things that I am
> interested in. I may just be a dunce, however.
> my two cents,
> Stephen Sefick
> On Tue, Aug 3, 2010 at 8:22 AM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
>> On Tue, 3 Aug 2010, Jarek Jasiewicz wrote:
>>> r.watershed elevation=elev drainage=dirs streams=stream treshold=<some
>>> value>
>>> r.stream.order streams=streams dirs=dirs hack=longest
>>> the stream with order 1 will be the longest streams of the catchment
>> Jarek,
>> Please correct me if I'm wrong, but I don't believe this answers David's
>> question. Using both the Horton and Strahler systems of calculating stream
>> order, order 1 is the headwater reach. However, a drainage basin does not
>> have each stream length from origin to outlet the same length.
>> I believe that what David asked is how to calculate the longest path from
>> the top of first order streams to the basin outlet.
>> Thinking about this now, I can see that looping across all streams from
>> headwaters to outlet, and presenting those in a table (with some indication
>> of which path has which length) would be highly useful. One could calculate
>> average stream length and other descriptive statistics that could be
>> cleverly applied to questions of runoff, flooding, and habitats
>> (particularly if incorporated with gradient measures and a few other basin
>> attributes).
>> You research guys could work on this; us applied folks need to focus on
>> billable work. :-)
>> Rich
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Stephen Sefick
> | Auburn University |
> | Department of Biological Sciences |
> | 331 Funchess Hall |
> | Auburn, Alabama |
> | 36849 |
> |___________________________________|
> | sas0025 at auburn.edu |
> | http://www.auburn.edu/~sas0025 |
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods. We are mammals, and have not exhausted the
> annoying little problems of being mammals.
> -K. Mullis
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
-K. Mullis
