[GRASS-user] Filling Null values in a MODIS image
Hanlie Pretorius
hanlie.pretorius at gmail.com
Wed Aug 4 04:29:16 EDT 2010
I have a MODIS land cover image that contains NULL values according to r.univar:
r.univar map=modis_land_cover_type1_2001_primary at PERMANENT
total null and non-null cells: 41884
total null cells: 17145
So, I tried to fill it with r.fillnulls and I get the following:
r.fillnulls input=MCD12Q1.A2001001.005_land_cover_type1 at PERMANENT
output=MCD12Q1.A2001001.005_land_cover_type1_filled
Locating and isolating NULL areas...
Reading input raster map <r_fillnulls_1911 at PERMANENT>...
Writing output raster map <r_fillnulls_1911.buf>...
Creating interpolation points...
Extracting points...
Building topology for vector map <vecttmp_fillnulls_1911>...
Registering primitives...
0 primitives registered
0 vertices registered
Building areas...
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 0
Number of primitives: 0
Number of points: 0
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
r.to.vect complete.
Interpolating 0 points
Not sufficient points to interpolate. Maybe no hole(s) to fill in the
current map region?
Removing raster <MASK>
Removing raster <r_fillnulls_1911>
Removing raster <r_fillnulls_1911.buf>
Removing raster <r_fillnulls_1911_filled>
Raster map <r_fillnulls_1911_filled> not found
<r_fillnulls_1911_filled> nothing removed
Removing vector <vecttmp_fillnulls_1911>
(Wed Aug 4 10:18:22 2010) Command finished (0 sec)
Output of g.region -p:
g.region -p rast=modis_land_cover_type1_2001_primary at PERMANENT res=0.00423094
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 27:19:08.833466S
south: 28:30:53.475952S
west: 28:03:57.840271E
east: 28:41:37.727966E
nsres: 0:00:15.210751
ewres: 0:00:15.269511
rows: 283
cols: 148
cells: 41884
Output of r.info:
r.info map=modis_land_cover_type1_2001_primary at PERMANENT
| Layer: modis_land_cover_type1_2001_p Date: Thu Jul 29 15:17:55 2010
| Mapset: PERMANENT Login of Creator: hanlie
| DataBase: /media/0847147784/grassdata
| Title: ( MCD12Q1.A2001001.005_land_cover_type1 )
| Timestamp: none
| Type of Map: raster Number of Categories: 14
| Data Type: CELL
| Rows: 11957
| Columns: 6277
| Total Cells: 75054089
| Projection: Latitude-Longitude
| N: 27:19:08.833466S S: 28:30:53.475952S Res: 0:00:00.36001
| E: 28:41:37.727966E W: 28:03:57.840271E Res: 0:00:00.36002
| Range of data: min = 1 max = 14
| Data Description:
| generated by r.in.gdal
| Comments:
| r.in.gdal input="F:\Hanlie\UCT\M.Sc\Data\modis\MOD12Q1\MCD12Q1.A2001\
| 001.h20v11.005.2009342153812_land_cover_type1.tif" output="MCD12Q1.A\
| 2001001.005_land_cover_type1"
I have tried to see the NULLS by displaying everything in white,
except for NULLS displayed in red, but I didn't see anything.
Does anyone know how I can find out if there are actually NULL value
and where they are?
Thanks
Hanlie
