[GRASS-user] Problems with a GeoTIFF referenced in Gauss Boaga
system
Daniel Victoria
daniel.victoria at gmail.com
Thu Aug 5 10:44:39 EDT 2010
You need to create a Location in Grass were the coordinate system is
the Gauss Boaga. Your current location has no reference system, it's a
XY location, as g.region -p output shows.
When you start Grass ask for it to create a new location based on a
georeferenced file. Then point to your GeoTiff and the location should
be set correctly. After that, r.in.gdal should work.
Daniel
On Thu, Aug 5, 2010 at 11:14 AM, Giacomo Piva <piva at meeo.it> wrote:
> Hi all,
> I'm fighting with r.in.gdal function and a GeoTiff gereferenced in the Gauss
> Boaga system.
> I have this GeoTiff that is originlly georeferenced in the WGS84 system and
> I need to convert it into Gauss Boaga system using the "gdalwarp" GDAL
> command tool.
> Moreover I need to convert this raster in a shapefile using the r.to.vect
> GRASS command.
> This is the (correct) gdalinfo output of mu Gauss Boaga GeoTiff:
> Coordinate System is:
> PROJCS["Monte Mario / Italy zone 1",
> GEOGCS["Monte Mario",
> DATUM["Monte_Mario",
> SPHEROID["International 1924",6378388,297.000000000005,
> AUTHORITY["EPSG","7022"]],
> AUTHORITY["EPSG","6265"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4265"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",9],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",1500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","3003"]]
> When I run the command
> r.in.gdal -o -e input=<inputfile.tif> output=inputraster location=location
> I get this error about the region
> ERROR: region for current mapset is not set
> run "g.region"
> The g.region -p command return:
> projection: 0 (x,y)
> zone: 0
> north: 2030
> south: 0
> west: 0
> east: 1354
> nsres: 1
> ewres: 1
> rows: 2030
> cols: 1354
> cells: 2748620
> How should I do?
> The same image georeferenced in the WGS84 system is properly loaded, so I'm
> wondering about to convert the GeoTiff AFTER loading int GRASS, but I don't
> know how.
> Does someone can help me?
> Thank you
> Giacomo
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
