[GRASS-user] Problems with a GeoTIFF referenced in Gauss Boaga system
Giacomo Piva piva at meeo.it
Thu Aug 5 11:07:37 EDT 2010
No... it don't work.
On 08/05/2010 04:39 PM, Paul Kelly wrote:
> On Thu, 5 Aug 2010, Giacomo Piva wrote:
>> When I run the command
>> r.in.gdal -o -e input=<inputfile.tif> output=inputraster
>> location=location
>> I get this error about the region
>> ERROR: region for current mapset is not set
>>       run "g.region"
> Just a suggestion to try - does it work without the -e flag? The
> "location" option automatically sets the extents of the new location
> to the same as your data, so as far as I can see you should not need
> the -e flag. Although that may not be related to the error; I'm not
> sure...
> However if that turns out to be the problem, a check should be added
> to warn that -e and location= are incompatible. Also I think the
> message to just "run g.region" is confusing; I guess it refers to the
> old interactive g.region?
> Paul
Giacomo Piva
MEEO S.r.l.
Via Saragat 9
I-44122 Ferrara, Italy
Tel: +39 0532 1861501
Fax: +39 0532 1861637
http://www.meeo.it
"ATTENZIONE:le informazioni contenute in questo messaggio sono
da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
per errore è tenuto ad informare il mittente ed a rimuoverlo
definitivamente da ogni supporto elettronico o cartaceo."
"WARNING:This message contains confidential and/or proprietary
information which may be subject to privilege or immunity and which
is intended for use of its addressee only. Should you receive this
message in error, you are kindly requested to inform the sender and
to definitively remove it from any paper or electronic format."
