[GRASS-user] Problems with a GeoTIFF referenced in Gauss Boaga
	system
    Daniel Victoria
    daniel.victoria at gmail.com
    Thu Aug  5 13:14:00 EDT 2010
Well, you are running Grass in a different way then... not sure if I
can help. Maybe try the location parameter in r.in.gdal. It's suposed
to create an appropriate location before importing the data...
Daniel
On Thu, Aug 5, 2010 at 12:19 PM, Giacomo Piva <piva at meeo.it> wrote:
> On 08/05/2010 04:44 PM, Daniel Victoria wrote:
>> You need to create a Location in Grass were the coordinate system is
>> the Gauss Boaga. Your current location has no reference system, it's a
>> XY location, as g.region -p output shows.
>> When you start Grass ask for it to create a new location based on a
>> georeferenced file. Then point to your GeoTiff and the location should
>> be set correctly. After that, r.in.gdal should work.
> This is the point.
> I'm using GRASS without UI,  only running command by a bash script.
> Actually I'm using a location (I don't remember how I made it) by setting up
> the grassrc file with the information about it:
> echo "LOCATION_NAME: start" > .grassrc6
> echo "MAPSET: PERMANENT" >> .grassrc6
> echo "DIGITIZER: none" >> .grassrc6
> echo "GISDBASE: $GISDBASE" >> .grassrc6
> export GISRC=.grassrc6
> then I read the input data ant then I change the location "jumping" into the
> region just created with the r.in.gdal command.
> How can I set the region by scratch or convert the location to a
> georeferenced location?
> I also tied to use the g.proj command in order to get the georefernce of the
> input image and try to set the region but the result is the same:
> g.proj georef=<input file> location=<location>
> Trying to open with OGR...
> Trying to open with GDAL...
> ...succeeded.
> g.proj -d
> XY location (unprojected)
> g.region -p
> projection: 0 (x,y)
> zone:       0
> north:      2030
> south:      0
> west:       0
> east:       1354
> nsres:      1
> ewres:      1
> rows:       2030
> cols:       1354
> cells:      2748620
>> Daniel
>> On Thu, Aug 5, 2010 at 11:14 AM, Giacomo Piva<piva at meeo.it>  wrote:
>>> Hi all,
>>> I'm fighting with r.in.gdal function and a GeoTiff gereferenced in the
>>> Gauss
>>> Boaga system.
>>> I have this GeoTiff that is originlly georeferenced in the WGS84 system
>>> and
>>> I need to convert it into Gauss Boaga system using the "gdalwarp" GDAL
>>> command tool.
>>> Moreover I need to convert this raster in a shapefile using the r.to.vect
>>> GRASS command.
>>> This is the (correct) gdalinfo output of mu Gauss Boaga GeoTiff:
>>> Coordinate System is:
>>> PROJCS["Monte Mario / Italy zone 1",
>>>    GEOGCS["Monte Mario",
>>>        DATUM["Monte_Mario",
>>>            SPHEROID["International 1924",6378388,297.000000000005,
>>>                AUTHORITY["EPSG","7022"]],
>>>            AUTHORITY["EPSG","6265"]],
>>>  PRIMEM["Greenwich",0],
>>>        UNIT["degree",0.0174532925199433],
>>>        AUTHORITY["EPSG","4265"]],
>>>    PROJECTION["Transverse_Mercator"],
>>>    PARAMETER["latitude_of_origin",0],
>>>    PARAMETER["central_meridian",9],
>>>    PARAMETER["scale_factor",0.9996],
>>>    PARAMETER["false_easting",1500000],
>>>    PARAMETER["false_northing",0],
>>>    UNIT["metre",1,
>>>        AUTHORITY["EPSG","9001"]],
>>>    AUTHORITY["EPSG","3003"]]
>>> When I run the command
>>> r.in.gdal -o -e input=<inputfile.tif>  output=inputraster
>>> location=location
>>> I get this error about the region
>>> ERROR: region for current mapset is not set
>>>       run "g.region"
>>> The g.region -p command return:
>>> projection: 0 (x,y)
>>> zone:       0
>>> north:      2030
>>> south:      0
>>> west:       0
>>> east:       1354
>>> nsres:      1
>>> ewres:      1
>>> rows:       2030
>>> cols:       1354
>>> cells:      2748620
>>> How should I do?
>>> The same image georeferenced in the WGS84 system is properly loaded, so
>>> I'm
>>> wondering about to convert the GeoTiff AFTER loading int GRASS, but I
>>> don't
>>> know how.
>>> Does someone can help me?
>>> Thank you
>>> Giacomo
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Giacomo Piva
> MEEO S.r.l.
> Via Saragat 9
> I-44122 Ferrara, Italy
> Tel: +39 0532 1861501
> Fax: +39 0532 1861637
> http://www.meeo.it
> "ATTENZIONE:le informazioni contenute in questo messaggio sono
> da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
> al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
> per errore è tenuto ad informare il mittente ed a rimuoverlo
> definitivamente da ogni supporto elettronico o cartaceo."
> "WARNING:This message contains confidential and/or proprietary
> information which may be subject to privilege or immunity and which
> is intended for use of its addressee only. Should you receive this
> message in error, you are kindly requested to inform the sender and
> to definitively remove it from any paper or electronic format."
