[GRASS-user] GeoTIFF output question (number of bytes divisible by 8?)
Markus Metz markus.metz.giswork at googlemail.com
Mon Aug 9 10:36:10 EDT 2010
stephen sefick wrote:
> If anyone is interested I had to export the files in AAIGrid format
Why did export directly to GeoTIFF not work?
> with a no data value =0 (elevations well above sea level) and then use
> gdal_translate to turn this into a geotiff.
> #GRASS out
> r.out.gdal input=fcms at PERMANENT output=/home/ssefick/Desktop/fcms
> nodata=0 format=AAIGrid
> #translate to goetiff
> gdal_translate -of GTIFF fcms fcms_g.tiff
> then tauDEM command line functions seem to work fine.
> If I am missing something please inform me.
> Again, thanks for all of the help!
> Stephen Sefick
> On Mon, Aug 9, 2010 at 8:06 AM, stephen sefick <ssefick at gmail.com> wrote:
>> Thank you- I will figure all of this out one day...  I thank you all
>> for your kind support.
>> kindest regards,
>> Stephen Sefick
>> On Mon, Aug 9, 2010 at 8:05 AM, Markus Metz
>>>> I am using
>>>> r.out.tiff -t input=fcms at PERMANENT output=/home/ssefick/Desktop/fcms.tiff
>>> Use
>>> r.out.gdal input=fcms at PERMANENT output=/home/ssefick/Desktop/fcms.tiff
>>>> for input into the tauDEM pitremove function (compiled from source)
>>> BTW, with r.out.tiff you get a standard tiff image with color values
>>> (0 - 255, 3 bands for RGB), not elevation values.
>>> Markus M
>> Stephen Sefick
>> ____________________________________
>> | Auburn University                                   |
>> | Department of Biological Sciences           |
>> | 331 Funchess Hall                                  |
>> | Auburn, Alabama                                   |
>> | 36849                                                    |
>> |___________________________________|
>> | sas0025 at auburn.edu                             |
>> | http://www.auburn.edu/~sas0025             |
>> Let's not spend our time and resources thinking about things that are
>> so little or so large that all they really do for us is puff us up and
>> make us feel like gods.  We are mammals, and have not exhausted the
>> annoying little problems of being mammals.
>>                                 -K. Mullis
> Stephen Sefick
> | Auburn University                                   |
> | 331 Funchess Hall                                  |
> | Auburn, Alabama                                   |
> | 36849                                                    |
>                                 -K. Mullis
