[GRASS-user] Clipping rasters
Jarek Jasiewicz
jarekj at amu.edu.pl
Tue Aug 10 10:58:19 EDT 2010
Hanlie Pretorius pisze:
> Hi,
> I thought I created a clipped DEM by rasterising an irregular vector
> boundary and then using a mask to create the clipped DEM from a
> rectangular DEM.
> For example:
> # convert vector border to raster
> v.to.rast input="border" output="border" use="cat" type="area" layer=1
> value=1 rows=4096 |
> # set the mask to the raster border
> r.mask border
> # create the clipped DEM
> r.mapcalc
>> dem_clipped=dem_full
> # remove the mask
> r.mask -r
> But it turns out I was wrong, the 'clipped' raster just contains NULL
> values outside of the border raster. What did I do wrong? Is there a
> better way to clip a raster to a vector boundary?
> Thanks
> Hanlie
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
nothing, everything is OK, if you want change raster size (i.e remove
areas outside vector) just do
g.region vect=border
value=1 rows=4096
etc..
but you will still will have null values outside the the vector, if it has irregular shape
J.
