[GRASS-user] Importing multiple files with r.in.xyz
Hanlie Pretorius
hanlie.pretorius at gmail.com
Tue Aug 10 11:09:18 EDT 2010
Thanks for the suggestions.
I think I'm going to try the Linux version as soon as I can get to a
Linux machine.
2010/8/10, Saber Razmjooei <razmjooeis at faunalia.co.uk>:
> Hanile
> Try this:
> 1- Install Paths:
> http://www.textpad.com/add-ons/files/utilities/paths.zip
> It's a useful tool to copy the path and filenames in windows. It adds a
> function to rightclick: Pathcopy. You can select all your rasters and
> rightclick to copy the paths:
> Paste them in a text file
> c:\example\raster1.xyz
> c:\example\raster2.xyz
> 2- change them to something like this (use find/replace..macros, etc:)
> r.in.xyz -s -g input="c:\example\raster1.xyz" output=raster1 > tmpRegion
> SET /p myregion= < tmpRegion
> DEL tmpRegion
> g.region %myregion%
> r.in.xyz --overwrite input="c:\example\raster1.xyz" output=raster1 fs=,
> 3- Save that as a import.bat
> 4- From the Start menu, run Grass in Txt mode, change directory to the
> folder where import.bat is
> 5- import.bat
> If you google around you should be able to make the script a bit smarter
> using DOS and loop (http://www.robvanderwoude.com/ntfor.php).
> In linux for example you can shrink it to something like this:
> cat list_of_files.txt | while read line; do
> echo $line+"Being processed" # or whaterver you want to do with the
> $line variable
> raster=$line
> r.in.xyz -s -g input=$line output=$line > tmpRegion
> myregion= ""`head -n 1 tmpRegion`"
> g.region $myregion
> r.in.xyz --overwrite input=$line output=$line fs=,
> done
> and your list_of_files.txt is
> raster1
> raster2
> Hope that helps
> Saber
> On Tue, 2010-08-10 at 14:59 +0200, Hanlie Pretorius wrote:
>> Hi,
>> I'm working with WinGRASS 6.4RC6 on Win XP.
>> I'm following the steps at http://grass.osgeo.org/wiki/Import_XYZ to
>> import hundreds files containing TRMM rainfall data.
>> When I try to follow the instruction:
>> Just amend above procedure to use wildcards. Change in above example
>> all occurencies of
>> cat VTL2733.XYZ | ...
>> to
>> cat *.XYZ | ...
>> and use a more reasonable output name of course. That's all to import
>> even thousands of files (tiled DEM) easily.
>> Not sure what a 'reasonable output name is', so I run it as shown
>> below and get the following error:
>> cat F:\Hanlie\UCT\M.Sc.\Data\TRMM\2000\02_Februrarie\*.txt| r.in.xyz
>> -s in=- fs=, out=test
>> cat: F:\Hanlie\UCT\M.Sc.\Data\TRMM\2000\02_Februrarie\*.txt: No such
>> file or directory
>> If I try it with one file only, it works:
>> cat
>> F:\Hanlie\UCT\M.Sc.\Data\TRMM\2000\02_Februrarie\3B42.000201.0.6.nc.lieb.txt|
>> r.in.xyz -s in=- fs=, out=test
>> Range:
>> x: -28.625000 -27.375000
>> y: 28.125000 28.625000
>> z: 0.000000 0.000000
>> How do I get this to work? And how would I get the output filenames to
>> be related to the input filenames? For example, if the input filename
>> is 3B42.000201.0.6.nc.lieb.txt, then I want the output raster to be
>> named '3B42.000201.0.6'.
>> Thanks
>> Hanlie
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
