[GRASS-user] river network modelling
Hamish
hamish_b at yahoo.com
Fri Aug 13 17:14:32 EDT 2010
ISTR that the streams and the subbasins share the same category number,
which should make selecting out the subbasin quite easy.
Hamish
--- On Thu, 8/12/10, Daphne Anhoehe <dafne.anhohe at googlemail.com> wrote:
From: Daphne Anhoehe <dafne.anhohe at googlemail.com>
Subject: Re: [GRASS-user] river network modelling
To: "Rich Shepard" <rshepard at appl-ecosys.com>
Cc: grass-user at lists.osgeo.org
Date: Thursday, August 12, 2010, 11:01 AM
Thank you very much for the suggestion! I will try that after selecting the subbasin that contains at least one of my points.
Dafne
On 12 August 2010 17:51, Rich Shepard <rshepard at appl-ecosys.com> wrote:
On Thu, 12 Aug 2010, Daphne Anhoehe wrote:
I used r.watershed to get the streams channels and now I am looking for an
automatic way to dismiss the part of the network above the points of
interest for my application.
Is that any tool to do that with GRASS?
Dafne,
Yup. Make a mask (see r.mask) and use that to either select the subbasin
you want or to remove the portion you don't want.
Rich
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100813/6e9166cb/attachment.html
