[GRASS-user] v.dissolve - is this a bug?
    Richard Chirgwin
    rchirgwin at ozemail.com.au
    Sat Aug 14 04:16:05 EDT 2010
In running v.dissolve within a script, I am getting an intermittent failure:
ERROR: key column must be integer or string
Here's the script spot that fails (but only sometimes)
v.db.addtable MAP
v.db.addcol MAP columns="Dissolve int"
v.db.update MAP column=Dissolve value=1
v.dissolve MAP output=DISSOLVE column=Dissolve
The killer is that it isn't reliable - sometimes it works, sometimes it
fails, and I can't tell why!
Richard C
