[GRASS-user] v.dissolve - is this a bug?
    Nikos Alexandris
    nikos.alexandris at felis.uni-freiburg.de
    Mon Aug 16 04:14:04 EDT 2010
Richard Chirgwin:
> > In running v.dissolve within a script, I am getting an intermittent
> > failure:
> > ERROR: key column must be integer or string
> > Here's the script spot that fails (but only sometimes)
> > v.db.addtable MAP
> > v.db.addcol MAP columns="Dissolve int"
Markus N:
> At this point, please run
> v.info -c MAP
> and report here.
> > v.db.update MAP column=Dissolve value=1
> > v.dissolve MAP output=DISSOLVE column=Dissolve
> > The killer is that it isn't reliable - sometimes it works, sometimes it
> > fails, and I can't tell why!
> Always on the same machine, the same binary and the same map?
Markus, Richard,
in the past I witnessed some strange randomness myself. Can't find the post
anymore (where Markus was referring to Heisenberg or someone's
uncertainty theory?).
Cheers, Nikos
