[GRASS-user] addons installation under GRASS 7.0-svn
Glynn Clements
glynn at gclements.plus.com
Mon Aug 16 18:01:33 EDT 2010
Michael Barton wrote:
> > Oh... :-O. Shell script(ing) ability completly removed in grass7x?
> > @devs: please keep the very minimum of shell script support if possible. Often
> > it is so much faster to work in the shell...
> I've been sort of out the dev loop for several months, but I'm
> pretty sure that 'lack of shell-script support' means that shell
> scripts are not currently recognized by the interface parser. That
> means that a shell script invoking GRASS will not produce an
> automatically generated wxPython GUI window.
That is incorrect; g.parser still works with shell scripts. Tested and
confirmed with the latest SVN version (r43153).
