[GRASS-user] SVN problems
    Daniel Victoria
    daniel.victoria at gmail.com
    Tue Aug 17 09:57:16 EDT 2010
Well, I'm a bit embarrassed but I found the problem... Wrong proxy
settings.... I checked out the code from SVN just fine but now I'm
having problems compiling.
I get errors in lib/gmath that says:
 /home/daniel/grass/grass6_devel/lib/gmath/blas_level_1.c:91:
undefined reference to `sqrt'
Am I missing some library?
Daniel
On Mon, Aug 16, 2010 at 8:57 PM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> It's probably some local problem then.... I can ping the server but
> can't checkout the code...
> Daniel
> On Mon, Aug 16, 2010 at 7:59 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Mon, Aug 16, 2010 at 11:57 PM, Daniel Victoria
>>> Hi all,
>>> I'm trying to checkout the code from SVN but when I issue the command
>>> svn checkout https://svn.osgeo.org/grass/grass/branches/develbranch_6
>>> grass6_devel
>>> I get the following error:
>>> svn: OPTIONS of
>>> 'https://svn.osgeo.org/grass/grass/branches/develbranch_6': could not
>>> connect to server (https://svn.osgeo.org)
>>> Is it me?
>> Try
>> http://downforeveryoneorjustme.com/
>>> Or is the server experiencing problems?
>> From Italy it looks good at time, no problems.
>> Markus
