[GRASS-user] addons installation under GRASS 7.0-svn
    Glynn Clements
    glynn at gclements.plus.com
    Wed Aug 18 01:35:13 EDT 2010
Markus Neteler wrote:
> >> GRASS 7.0.svn (nc_spm_08): > sh i.fusion.his
> >> sh: i.fusion.his: command not found
> > Does it have the execute bit set?
> Yes.
> > If it doesn't, g.parser can't
> > execute it. That has always been the case; it isn't specific to 7.0.
> ls -la i.fusion.his
> -rwxr-xr-x 1 neteler neteler 3867 2009-09-29 21:36 i.fusion.his*
> The problem was that it wasn't in the search path.
I thought of mentioning this, then concluded that it shouldn't make a
difference. But it turns out that it matters if GRASS_GUI is set to
"wxpython".
If you "execute" a script by typing its name, it must be in $PATH. But
if you execute "sh" with the script filename as an argument, the shell
will just [f]open() it, and the normal rules apply (i.e. any path not
starting with a "/" is relative to the current directory).
And when g.parser invokes the script, it uses execl(), which doesn't
use the path.
AFAICT, the problem is when g.parser uses G_gui_wx(). Whereas
G_gui_tcltk() invokes gui.tcl and feeds it a description on its stdin,
G_gui_wx() invokes menuform.py with the command line, and G_gui_wx()
re-invokes the script with the --interface-description flag. The
script is exceuted using os.popen(), which uses /bin/sh, which uses
$PATH, hence the error.
So if you run the script with arguments (so that no dialog is
generated), or if GRASS_GUI is set to "tcltk", I think that it should
work regardless of whether the script is in $PATH.
