[GRASS-user] g.extension not working
Markus Neteler
neteler at osgeo.org
Wed Aug 18 09:14:09 EDT 2010
On Wed, Aug 18, 2010 at 2:28 PM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> Hi all,
> Just got 6.5svn compiled in Ubuntu 9.04 and I'm now trying to install
> r.stream.order using g.extension. When I give the command
> g.extension extension=r.stream.order prefix=${GISBASE}
(it should work without the prefix parameter)
> I get:
> [: 196: /home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu:
> unexpected operator
> [: 219: add: unexpected operator
I tried but do not get this error (which apparently doesn't harm, the
problem below is unrelated).
> And then the files are checked out from svn but compilation fails with
> the messages bellow. Any hints? Do I need to checkout other extensions
> first?
No, it is a declaration bug in r.stream.order.
> Thanks
> Daniel
> Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
> A r.stream.order/orders.png
> A r.stream.order/main.c
> A r.stream.order/description.html
> A r.stream.order/global.h
> A r.stream.order/io.c
> A r.stream.order/order.c
> A r.stream.order/Makefile
> Checked out revision 43156.
> Compiling <r.stream.order>...
> /home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/include/Make/Module.make:25:
> warning: overriding commands for target `install'
> /home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/include/Make/Rules.make:90:
> warning: ignoring old commands for target `install'
> test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
> gcc -I/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/include
> -g -Wall -Werror-implicit-function-declaration -fno-common
> -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grassmods"\"
> -I/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/include -o
> OBJ.i686-pc-linux-gnu/io.o -c io.c
> io.c: In function ‘create_base_maps’:
> io.c:57: warning: format not a string literal and no format arguments
> io.c: In function ‘write_maps’:
> io.c:172: warning: format not a string literal and no format arguments
> OBJ.i686-pc-linux-gnu/main.o -c main.c
> main.c: In function ‘main’:
> main.c:142: warning: format not a string literal and no format arguments
> OBJ.i686-pc-linux-gnu/order.o -c order.c
> order.c: In function ‘trib_nums’:
> order.c:24: warning: format not a string literal and no format arguments
> order.c:26: warning: format not a string literal and no format arguments
> order.c: In function ‘find_nodes’:
> order.c:68: warning: format not a string literal and no format arguments
> order.c:97: warning: format not a string literal and no format arguments
> order.c:108: warning: format not a string literal and no format arguments
> order.c:123: warning: format not a string literal and no format arguments
> order.c: In function ‘do_cum_length’:
> order.c:164: warning: format not a string literal and no format arguments
> order.c: In function ‘strahler’:
> order.c:259: warning: format not a string literal and no format arguments
> order.c: In function ‘shreeve’:
> order.c:313: warning: format not a string literal and no format arguments
> order.c: In function ‘horton’:
> order.c:364: warning: format not a string literal and no format arguments
> order.c: In function ‘hack’:
> order.c:447: warning: format not a string literal and no format arguments
> gcc -L/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/lib
> -Wl,--no-undefined -Wl,--export-dynamic
> -Wl,-rpath-link,/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/lib
> -L/usr/lib -o
> /home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/bin/r.stream.order
> OBJ.i686-pc-linux-gnu/io.o OBJ.i686-pc-linux-gnu/main.o
> OBJ.i686-pc-linux-gnu/order.o -lgrass_vect -lgrass_dbmibase
> -lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient
> -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis
> -lgrass_datetime -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis
> -lgrass_datetime -lz -lgrass_rtree -lgrass_gis -lgrass_datetime
> -lz -lgrass_linkm -lgrass_rtree -lgrass_dig2 -lgrass_gis
> -lgrass_datetime -lz -lgrass_rtree -lgrass_dgl -lgrass_rtree
> -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis
> -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz
> -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -L/usr/lib
> -lgdal1.7.0 -L/usr/lib -lgeos -lgeos_c -lgrass_dbmiclient
> -lgrass_datetime -lz -lgrass_dbmibase -lgrass_gis
> -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lm
> -lz
> OBJ.i686-pc-linux-gnu/main.o: In function `main':
> /home/daniel/grassdata/br_wgs84/jip/.tmp/xadrez/2602.0/r.stream.order/main.c:54:
> multiple definition of `springs'
> OBJ.i686-pc-linux-gnu/io.o:/home/daniel/grassdata/br_wgs84/jip/.tmp/xadrez/2602.0/r.stream.order/io.c:5:
> first defined here
these need to be defined "extern" I think.
@Jarek - could you please fix this?
> multiple definition of `outlets'
> first defined here
... many more ...
> collect2: ld returned 1 exit status
> make: *** [/home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu/bin/r.stream.order]
> Error 1
> ERROR: Compilation failed, sorry. Please check above error messages.
> GRASS 6.5.svn (br_wgs84):~ >
Once the declarations are fixed in r.stream.order it should work.
A trick for you: declare less -W parameters when configuring GRASS and
the compiler may work around the problem. Still it should be fixed in SVN.
Markus
