[GRASS-user] Flow Direction Map Question (r.stream.extract)
    stephen sefick
    ssefick at gmail.com
    Wed Aug 18 09:55:45 EDT 2010
I am trying to use a direction map from taudem with the r.stream
modules.  I think the problem may be that -8 to 8 is the range of
value in the r.stream extract version and 1-8 in the taudem version.
I can generate one with r.stream extract with the flow accumulation
and the filled DEM from taudem.  The raster stream network are very
similar, but not totally the same.  Any help would be greatly
appreciated
Stephen Sefick
____________________________________
| Auburn University                                   |
| Department of Biological Sciences           |
| 331 Funchess Hall                                  |
| Auburn, Alabama                                   |
| 36849                                                    |
|___________________________________|
| sas0025 at auburn.edu                             |
| http://www.auburn.edu/~sas0025             |
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods.  We are mammals, and have not exhausted the
annoying little problems of being mammals.
                                -K. Mullis
