Sandile Gumede wrote: > How was the mean calculated from the table below? these are the output of > v.db.select from v.rast.stats. Hi! As far as I understand, v.rast.stats is a script calling r.mapcalc to perform the calculations. Subsequently, calculations depend on the raster map(s) (size, resolution, data type, etc.) Regards, Nikos
