[GRASS-user] g.extension not working
Markus Neteler neteler at osgeo.org
Thu Aug 26 10:21:14 EDT 2010
On Wed, Aug 18, 2010 at 3:14 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Aug 18, 2010 at 2:28 PM, Daniel Victoria
> <daniel.victoria at gmail.com> wrote:
>> Hi all,
>> Just got 6.5svn compiled in Ubuntu 9.04 and I'm now trying to install
>> r.stream.order using g.extension. When I give the command
>> g.extension extension=r.stream.order prefix=${GISBASE}
> (it should work without the prefix parameter)
>> I get:
>> [: 196: /home/daniel/grass/grass6_devel/dist.i686-pc-linux-gnu:
>> unexpected operator
>> [: 219: add: unexpected operator
> I tried but do not get this error (which apparently doesn't harm, the
> problem below is unrelated).
>> And then the files are checked out from svn but compilation fails with
>> the messages bellow. Any hints? Do I need to checkout other extensions
>> first?
> No, it is a declaration bug in r.stream.order.
Jarek has fixed it in SVN. Now g.extension should work.
Cheers
Markus
