[GRASS-user] Unable to Edit vector map with grass64
Martin Landa landa.martin at gmail.com
Thu Aug 26 16:28:06 EDT 2010
2010/8/26 stephen sefick <ssefick at gmail.com>:
> I can use the grass64RC5 digitizer with good results?
RC5 is quite old (with few days should be released RC7). In any case
you can always use TCL/TK digitizer [1]. wxGUI vector digitizer can be
compiled manually, you just need to use specific version of swig
(usually 1.3.36). As I mentioned earlier wxGUI digitizer is going to
be fixed and in the result included later in 6.4.1.
Martin
[1] http://grass.osgeo.org/grass64/manuals/html64_user/v.digit.html
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
