[GRASS-user] bash scrip r.cost/r.drain
Anders Gonçalves da Silva
andersgs at gmail.com
Tue Aug 31 02:41:03 EDT 2010
Hi Micha.
Thank you very much. That worked like a charm. With that initial kick, I was able to create a little loop that goes through each point in my dataset, and outputs a column matrix with pairwise distances for each observation. Now, I just need to add more friction rasters.
Cheers,
Anders.
On 31/08/2010, at 12:32 AM, Micha Silver wrote:
> On Mon, 30 Aug 2010 20:38:40 +1000
> Anders Gonçalves da Silva <andersgs at gmail.com> wrote:
>> Hello all.
>> I was wondering if anyone has a bash script that runs over all pairs
>> of points in a vector file, using them each in turn as
>> start_coordinate in r.cost, and as a final point in r.drain. Thank
>> you. Or, something similar that I could easily modify to my purposes.
> You could probably start by throwing the points into a text file with
> v.out.ascii, then loop thru that file with something like:
> v.out.ascii <vector> out=ascii_vector_points.txt fs=space
> while read X Y ;
> do <your r.cost command coord=$X,$Y>;
> done < ascii_vector_points.txt
>> Anders._______________________________________________
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> This mail was received via Mail-SeCure System.
