[GRASS-user] modis ocean and r.in.gdal
Gustavo
gmpuljak at yahoo.com.ar
Thu Dec 2 19:33:37 EST 2010
Eduardo,
I am using the SMI format. I've tried the following with the same result.
Gustavo
gdal_translate -a_srs "+init=epsg:4326" -a_nodata 65535 -a_ullr -180 90 180
-90 -co "COMPRESS=PACKBITS"
HDF4_SDS:UNKNOWN:"A20100252010032.L3m_8D_CHL_chlor_a_9km":0 prueba.tif
Input file size is 4320, 2160
0ERROR 1: SDreaddata() failed for block.
ERROR 1: IReadBlock failed at X offset 0, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
On Jue 02 Dic 2010 20:48:22 Eduardo Klein escribió:
> Gustavo, are you working with the SMI/HDF product? I've just run the
> script in grass 6.4.0 and it worked perfect. Check with gdalinfo the
> name of the subset to process (usually something like
> HDF4_SDS:UNKNOWN:"A20101292010136.L3m_8D_SST_9":0)
> Saludos, EKS
