[GRASS-user] v.in-out quirks
Micha Silver
micha at arava.co.il
Fri Dec 3 07:07:30 EST 2010
On 12/02/2010 02:01 PM, Shane Litherland wrote:
> hi all you GRASSers ;-)
> not sure what happened when i first tried to join the mailing list a few
> months ago, but i got my user/subscription sorted now :-)
> I have been using GRASS for a couple years now, more consistently in the
> last 12 months after a steady learning process. So hopefully as I come
> across 'things' there's less likelihood it's just me being a silly
> novice (less, but not a surety..)
> my latest fiddling has been with import of GPS data by a few different
> means, and some issues I struck.
> my methods:
> GPS to .gpx file using GEBABBEL (GUI for gpsbabel);
> .gpx file has:
> wpt (waypoints co-ords lat-long)
> ele (elevation)
> name (the name/number I gave each waypoint when I marked them)
> cmt (supposedly a comment, it is the date/time)
> desc (date/time again)
> sym (name of symbol used in gps)
Here's an idea that might work for you (tested only briefly...)
gpsbabel has a file format 'unicsv' that throws the data into a comma
separated list, with headers. That can be piped straight into v.in.ascii
with some careful choice of parameters.
Here's what worked for me:
gpsbabel -t -i gpx -o unicsv -f bike_rides_1208.gpx -F - | v.in.ascii
out=bike_rides2 fs=, col="num integer, y_coord double, x_coord double,
elev double, date_str varchar(16), time_str varchar(16)" x=3 y=2 skip=1
I had a gpx file already downloaded from the gps, but no reason this
wouldn't work pulling the data right off the unit. The gpsbabel command
include "-F -" (note the trailing dash) to indicate that the output just
goes to STDOUT. Then it's piped into v.in.ascii (inside a grass session,
of course). You need the "fs=," since the csv is indeed comma separated.
Then you use the col="..." to give any name/type you want to each of the
gps attributes. Next be careful to choose the correct column numbers for
X and Y (duh!) and finally add "skip=1" to skip the first line of gps
column headers.
If this helps, please post back...
Micha
> v.in.ogr to import gpx file to GRASS;
> using Postgres as database;
> specifying just one layer (e.g. waypoints);
> ... get an error when v.in.ogr tries to create table in postgres -
> doesn't like 'desc' as a column name (one of those special db words).
> ...OK, so I can change the column names with cnames, but then it was
> upset by 'time datetime' that corresponded to what should be 'name
> varchar' in the .gpx file.
> ... or change 'desc' to 'description' in the .gpx file- but no, the
> error still happens, seems the 'desc' cname is built into the v.in.ogr,
> it's not checking any of the cnames with the input file
> ...but I also note in the output that the columns generated by the
> v.in.ogr are way more than I have in the .gpx file, and the column
> formats for the first few columns don't all match the formats for the
> data they'd 'find' in the .gpx file.
> ... was wondering how then, I might get to the part of the v.in.ogr
> module(?) that has all these columns to edit it...?? I did try in the
> cnames, including 'name format' like i'd do when making a table, but
> that confused the poor v.in.ogr (showed 'name format format' in the
> output and didn't like making a table that way!)
> ... can check the box to 'not create attribute table' and import it OK
> but of course, any waypoint name/info doesn't make it into GRASS /
> postgres.
> ...OK, so v.in.ogr might not be the way to get .gpx stuff into grass
> anyway, but i'm trying things out here!
> my next approach-
> v.in.gpsbabel;
> using .gpx format;
> ... it runs OK, but generates a table with:
> cat (added for the db)
> x (lat)
> y (long)
> altitude (elevation)
> gmt_date (blank - zero string length when table created)
> gmt_time (blank - ditto)
> comments (obvious)
> when what was in the .gpx file was really
> (cat - to be added for the db)
> x
> y
> ele
> name
> cmt ('comment' actually datetime)
> description (also datetime)
> ... so, whilst the v.in.gpsbabel got the waypoints in, it too 'lost' the
> name of each waypoint and mucked up the date/time field/format when
> populating the table.
> I have not tried creating a db table directly (i.e. in postgres) and
> then creating vector in GRASS and connecting them, as I figure the only
> field i could safely link them on would be the datetime, because cats
> generated during vector import probably wouldn't match the cats I made
> manually in the table... and if the datetime was mucked up in its format
> (e.g. as varchar instead) ... well, I just reckon that option could be
> rather messy ;-)
> Of course, I seem to have 'missed' the obvious option of directly
> importing from the GPS unit to GRASS... well, I tried, but had to go and
> figure out how the GPS connected to my computer (in Ubuntu 10.04, the
> default connection shown in v.in.garmin of /dev/gps wasn't found)
> ...after getting fresh batteries for my gps, I tried connecting via:
> /dev/usb
> /dev/usbmon0 (thru to mon7)
> /dev/ttyS0
> /dev/USB0
> /dev/tty0
> usb:
> ...these 'ideas' from bits I saw in other GUI's and/or on the web, but
> to no avail - the receiver did not respond on any of these ports.
> I know gpsbabel (gebabbel GUI) connected to the unit with the "usb:"
> setting because that's how I made my .gpx file in the first place.
> I know of other 'workarounds' e.g. I have (a while ago) run the old
> Mapsource in Wine, and then get the waypoints/tracks etc into a format
> for GRASS, had also played with gpsman and some other bits. But I'm not
> elaborating on those workarounds, at the moment it's more about sharing
> my experience on how the more direct options didn't-quite-work ;-)
> At the end of all that, I guess if I knew how to edit the v.in.ogr /
> v.in.garmin / etc, I could tweak the bits to work..? but (I find this
> bemusing still) these are .bin files, so despite them being part of an
> open-source software, they are, from my perspective, still 'closed' as
> far as being able to know what's going on in there ;-) and i'm not sure
> i'm quite skilled enough to play too much with those binary-readers... i
> could do something wrong and break things...
> That's my 'quirk of the month' session done :-) I hear the sighs of
> relief!
> As an aside, I've been considering putting in bits for manuals/tutorials
> along the way - my use of GRASS is more-or-less from an ecological and
> land-management perspective and not in-depth, but OK for e.g.
> entry/undergraduate level users... thoughts/contacts welcome on this one
> too.
> Regards,
> Shane.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
