[GRASS-user] Re: Projection problems with EU soil data [SOLVED]
Francesco P. Lovergine
frankie at debian.org
Sat Dec 4 20:15:58 EST 2010
On Fri, Dec 03, 2010 at 11:51:06AM +0100, Francesco P. Lovergine wrote:
> The ESDB data here available:
> http://eusoils.jrc.ec.europa.eu/ESDB_Archive/ESDB_Data_Distribution/ESDB_data.html
> still have a peculiar LAEA projection with spherical ellipsoid as
> explained here:
> http://eusoils.jrc.ec.europa.eu/gisco_dbm/dbm/home.htm
> (see The Lambert Azimuthal Equal Area projection)
> and indeed this is the output of ogrinfo about them:
I finally found that the accompanying .prj are simply outdated.
The projection used adopts a GRS80 ellipsoid as in ETRS89, but still
use the same parameters for the rest.
+proj=laea
+lat_0=48.0000000000
+lon_0=9.0000000000
+x_0=0.0000000000
+y_0=0.0000000000
+a=6378137
+rf=298.257222101
+no_defs
+to_meter=1.0
