Daniel Victoria wrote: > I'm using WinGrass 7.0svn from the daily build and I just realized > that i.spectral.py needs gnuplot. It shouldn't need gnuplot. It shouldn't even try to use gnuplot unless you use the -g flag. The default behaviour is to use d.linegraph. -- Glynn Clements <glynn at gclements.plus.com>
