[GRASS-user] Assign attributes of start and enpoints to, connecting lines
Richard Chirgwin rchirgwin at ozemail.com.au
Sat Dec 11 15:33:41 EST 2010
On 12/12/10 4:00 AM, grass-user-request at lists.osgeo.org wrote:
> Message: 4 Date: Sat, 11 Dec 2010 17:09:06 +0200 From: Micha Silver
> <micha at arava.co.il> Subject: Re: [GRASS-user] Assign attributes of
> start and enpoints to connecting lines To: Hanlie Pretorius
> <hanlie.pretorius at gmail.com> Cc: grass-user at lists.osgeo.org
> Message-ID: <4D039412.3080707 at arava.co.il> Content-Type: text/plain;
> charset=UTF-8; format=flowed On 12/10/2010 08:19 AM, Hanlie Pretorius
> wrote:
>> >  Hi Micha,
>> >  Thanks for the reply.
>> >  I tried your method using the GUI, and it seems one cannot have a
>> >  from_type of 'line', only of 'point' or 'centroid'.
> Yes, you're right. Sorry for misleading you. The 'from' map can be only
> points, so this won't help to get the node labels into the rivers table.
Convert the start and end nodes to points using v.to.points, and then
use v.distance?
Richard
