[GRASS-user] Assign attributes of start and enpoints to connecting
lines
Hanlie Pretorius
hanlie.pretorius at gmail.com
Mon Dec 13 01:25:15 EST 2010
Hi Richard,
Your suggestion worked in principle, but the whole operation needs
more work. I ended up with the same node names in the start and end
node columns, so I think a script is needed to identify the start and
end nodes based on the direction of the flow of the river. An
elevation column in the points layer could provide this information.
Regards
Hanlie
> Date: Sun, 12 Dec 2010 07:33:41 +1100
> From: Richard Chirgwin <rchirgwin at ozemail.com.au>
> Subject: Re: [GRASS-user] Assign attributes of start and enpoints to,
> connecting lines
> To: grass-user at lists.osgeo.org
> Message-ID: <4D03E025.7040203 at ozemail.com.au>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Convert the start and end nodes to points using v.to.points, and then
> use v.distance?
> Richard
