[GRASS-user] SQL Error using "v.color"
Micha Silver micha at arava.co.il
Sun Dec 19 15:33:22 EST 2010
On 19/12/2010 14:44, rvanderweide at worldbank.org wrote:
> Dear GRASS,
> I am using the December 19 (2010) build of GRASS 6.4 for Windows. I
> have loaded a vector map (for a country with approx 20 province
> boundaries) with an attribute table that contains a continuous
> variable at the province level (name of column is `y2009'). Trying to
> put the `y2009' variable on the map, i begin with defining the color
> grading to be used by means of the following command:
> "GRASS 6.4> v.colors map=pse column=y2009 rgb_column=hc2 color=bcyr"
> Doing so I get the following error:
> Creating column <hc2> ...
> Scanning values ...
> Looking up colors ...
> Writing 16 colors ...
> DBMI-SQLite driver error:
> Error in sqlite3_prepare():
> near "SET": syntax error
> ERROR: Error while executing: 'UPDATE SET hc2 = '0:0:255' WHERE y2009 =
>        0.094713'
> ERROR: Processing SQL transaction
> rm: cannot remove `C://test/poverty/.tmp/636.0_vcol.sql': Permission
> denied"
> Any idea what is creating the error -- or what i am doing wrong? Is
> there a way to get around this/fix it?
I have a suggestion that might fix this problem. The v.colors script on
line 209 uses the expression:
grep "^$GIS_OPT_LAYER;"
to isolate the TABLE name, and I think that the windows version of grep
is confused by the semicolon ';'.
Please locate the script (should be under %GISBASE\scripts)  and open it
in an editor. Then replace line 209 as follows:
(original)
TABLE=`v.db.connect -g map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" fs=";"
| grep "^$GIS_OPT_LAYER;" | cut -f2 -d';'`
(change to:)
| grep "^$GIS_OPT_LAYER" | cut -f2 -d';'`
(just remove the ; from "^$GIS_OPT_LAYER" after grep)
Let us know if this works.
Regards,
Micha
> Many thanks in advance!
> Roy
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101219/895af616/attachment.html
