[GRASS-user] SQL Error using "v.color"
Micha Silver
micha at arava.co.il
Sun Dec 19 17:26:09 EST 2010
On 12/20/2010 12:07 AM, rvanderweide at worldbank.org wrote:
> Hi Hamish and Micha,
> Many thanks for your help.
> To follow up on your earlier comment, submitting: v.db.connect -g
> map=pse layer=1 fs=";"
> yields: 1/pse;pse;cat;C://test/poverty/sqlite.db;sqlite
Here's the problem. That slash and "pse" (layer name) after the digit '1'.
Any grep expression with a character following the $GIS_OPT_LAYER will
fail...
> Does this help?
> Thanks again,
> Roy
> -----Hamish <hamish_b at yahoo.com> wrote: -----
> To: Micha Silver <micha at arava.co.il>, rvanderweide at worldbank.org
> From: Hamish <hamish_b at yahoo.com>
> Date: 12/19/2010 04:43PM
> Cc: grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] SQL Error using "v.color"
> Roy:
> > Hi Micha, To follow up on my problem and your fix, I am no longer
> > getting the error message i used to get. When i look at the
> attribute
> > table, however, the RGB_column variable (which i named `hc2' in my
> > example) -- created by v.colors -- has a lot of missing values. Do
> > you have an idea why this is the case?
> one thing to try is to remove the hc2 column (v.db.dropcol) and
> try again.
> what does v.univar say about the numerical column?
> Hamish
> This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101220/f130339f/attachment-0001.html
