[GRASS-user] SQL Error using "v.color"
Hamish
hamish_b at yahoo.com
Sun Dec 19 21:25:09 EST 2010
> Roy:
> > Is there also an alternative way to map a continuous variable (using
> > different grades of colour to fill the area contained by boundaries),
> > i.e. where you do not necessarily have to create your own rgb_column?
> > (I have noticed an option for random colour assignment, but that is not
> > exactly what i want.)
Hamish:
> there is the d.vect.thematic module,
oh yeah, another trick: if you set the continuous column as the feature's z
(elevation) value you can use 'd.vect -z zcolor=bcyr' too. [v.edit or
v.extrude?]
Hamish
