[GRASS-user] i.spectral.py in WinGrass
Martin Landa
landa.martin at gmail.com
Fri Dec 24 07:20:06 EST 2010
2010/12/23 Martin Landa <landa.martin at gmail.com>:
>> the problem has been report on trac [1], closed without any clue.
> hm, it seems to be bug in GRASS windows installer, sorry for noise.
seems to be really mismatch of python versions. The test script
(below) is run by
C:\Program Files (x86)\GRASS-70-SVN\extrabin\python.exe (GRASS_PYTHON)
g.parser runs menuform.py - also by GRASS_PYTHON
them `r.test.py --interface-description` (called from menuform.py) is
run by another version of Python
C:\Python26\ArcGIS10.0\python.exe
...no clue why.
Martin
#!/usr/bin/env python
#%Module
#% description: Creates a raster map showing buffer zones surrounding
cells that contain non-NULL category values.
#%End
#%Option
#% key: input
#% type: string
#% required: yes
#% multiple: no
#% key_desc: name
#% description: Name of input raster map
#% gisprompt: old,cell,raster
#%End
import sys
print >> sys.stderr, sys.executable
import grass.script as grass
grass.parser()
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
