[GRASS-user] Smaller area of a vector file
    Matteo Toro
    ciccpaol at libero.it
    Tue Feb  2 19:03:31 EST 2010
Ciao Christian
two lines...and works perfectly!
Thanks a lot!!
> Ciao Matteo,
> You can cut your vector file in Grass according to the current region defined with g.region by using v.in.region and then v.overlay.
> Otherwise, you can select the vector objects inside your current region using v.in.region and then v.select.
> Probably, there are other possible solutions to your problem I am not aware of...
> Hope I was clear enough.
> Christian
> I don't know whether it is the easiest way to do
> On 2 févr. 2010, at 19:04, Matteo Toro wrote:
> > Hi,
> > I have got a vector file of a big region.
> > I would like to export a small part of this vector file to an esri-type vector file.
> > How can I do it?
> > Thanks!
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
