[GRASS-user] Set language in Linux
Gilbert Ferrara
gilbertferrara1974 at gmail.com
Wed Feb 3 07:35:47 EST 2010
I just want to provide GRASS64 in two languages and without the user has to
define lang in the bash_profiles.
My idea was to create 2 files: grass64eng and grass64sp each one with
different language sets. So the user would have only to select the adequate
file. If this is not correct, what would be your suggestion?
Thank you in Advance
Gilbert
On Tue, Feb 2, 2010 at 7:07 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Gilbert Ferrara wrote:
> > For instance If I want to have 2 language sets available for a user, can
> > have two different bash_profiles? I mean have grass64eng for english
> > language and grass64sp for Spanish?
> > And are there any rules regarding bash_profiles files?
> ~/.bash_profile is read when starting a login shell. It isn't started
> for non-login shells.
> If you want to provide separate versions of the grass64 script, bash's
> startup files aren't relevant.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100203/8b39e251/attachment.html
